Ambient temp has changed maybe?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/643878-cooling-trouble/#findComment-8291403
51 minutes ago, Jw7777 said:
I have an AMD fx 8320 being cooled by a corsair h100i. For close to a year I had it OC at 4.2 ghz and temps were never over about 43 degrees Celsius. Recently the temps just went crazy. I'm reaching 53 degrees playing csgo at STOCK speeds. I can't figure out why
Could be dust on your radiator?
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/643878-cooling-trouble/#findComment-8291636
I cleaned them off already. But it wasn't slow for the temps rising. One day they are cool and stable with an OC and the next day I'm having to drop to stock speeds and max out my fan curve. Dust would slowly show performance decline
https://linustechtips.com/topic/643878-cooling-trouble/#findComment-8291783
True, I only was asking just to be sure.
Well, no ambient change, no dust, maximum airflow. How about the pump? Is that still running well?
Thermal paste is less than a year old I guess so that would probably not be the issue here.
https://linustechtips.com/topic/643878-cooling-trouble/#findComment-8292252
Corsair Link says the pump is running at just under 3000rpm so I do believe it is running properly
https://linustechtips.com/topic/643878-cooling-trouble/#findComment-8292288
