Partiton help, should be simple to solve
Solved by Energycore,
If you're keen on troubleshooting independently, and since you like the command line I bet you are, I'd say make a bootable USB with gparted (it's a linux bootable environment), then see if you can use that to merge the unallocated space bits. Maybe create a partition that spans all the unallocated space, then delete it.
Featured Topics
yepnew ·
TukangKopi ·
Posted in Networking2 -
2
12
14
Cramig88 ·
Posted in Networking0 -
6
