When I try to open CS:GO, I get the following error:
Your graphics hardware does not support all features (CSM) needed to run this game.
Device Info:
Marked unsupported: 0
Supports PCF Sampling: 0
DriverName: "Microsoft Basic Render Driver"
VendorID: 0x1414, DeviceID: 0x008C
DriverHigh: 0x00060003, DriverLow: 0x25804407
DXLevel: 95, MinDXSupportLevel: 90, MaxDXSupportLevel: 95
DXDIAG:
System: https://gyazo.com/279a9181c6f84b1daf637f2eac005f6a
Display: https://gyazo.com/57c676441db59be6424c09509c08936b
Render: https://gyazo.com/4ae74bb69744f74103d4aa1adb7fd981
https://linustechtips.com/topic/643719-microsoft-basic-render-device-issues/
Device Info:
DXDIAG:
Could be your drivers
Hello
4 minutes ago, psgreen11 said:
I've installed NVIDIA drivers a few times now, so I don't think it's just the drivers.
Even still, I'd keep digging on that. The Display tab should have info about your GPU and it's driver but there's nothing there. See here for reference. Another cause could be an issue with Optimus. You may need to force the Geforce on in the Nvidia control panel, assuming it's now stuck on the integrated GPU.
What would I need to do in the Nvidia control panel to fix Optimus or force the geforce on?
Use DDU to remove completely your drivers then install a slightly older version of drivers and see what happens
Hello
