PC Temps too high?
Solved by NunoLava1998,
Your TMP and AUX temperatures are broken. If it was at that temperature, the motherboard would probably melt or something. Don't worry. The program you're using also has some major errors.
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab0 -
1
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning15 -
1
3
play_circle_filled
Latest From ShortCircuit:
