Explain the freezes. When do they happen? And how long do they last?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/643624-new-build-with-a-problem/#findComment-8288831
Without any further description i'd say check the ram.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/643624-new-build-with-a-problem/#findComment-8288841
3 minutes ago, BenMatthew said:
u can hear the sounds, but u cant see anything... like u watching a screenshot, it happens randomly... All i can do is a reboot, then it works
Motherboard drivers not up to date? Can cause issues with the northbridge and cause a loss of connection with the GPU, used to happen to me.
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/643624-new-build-with-a-problem/#findComment-8288852
