So this is something I've always wondered - the world is moving to thinner laptops, tablets etc. There's been less focus on performance for standard users (Not gamers/video production). What I wondered is can you give performance of one pc dynamically to others? In essence could you have a beefy server which then donates performance to devices with slower processors so they can be smaller in size but still have that incredible performance. This is basically a step further from LTT 7 gamers 1 cpu.
Thanks
https://linustechtips.com/topic/643248-distributed-computing-at-home-is-it-possible/
yes
its very possible. i know the GPU side of things
THey have What are called Nvidia GRID gpus built for running VMs. a specific card os the Grid K1 which is a quad GPU card (all 4 based on GK 107, GTx 660 i believe) that can support 4 users with
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Just now, 007agentHP said:
yes
Obviously building a server style PC with heaps of performance is fairly easy - the bit I'm not quite sure about is the software side in terms of sharing performance.
look up nvidia grid
they have things like the grid k1 with 4 GPUS onboard for 4 users
the software side is dealt with VMs like VMware
Rigs I've Built
1 minute ago, 007agentHP said:
look up nvidia grid
they have thing slike the grid k1 with 4 GPUS onboard for 4 user.
With a vm the resources are fixed and run over the top of devices - I want to integrate this at a more fundamental level using consumer level hardware.
Depends on what you'd use it for - if it's for games that's steam in home streaming, on a vfio vm if you need it for other things simultaneously. If you think you can use a program and have your laptop magically pull performance from the other computer in exactly the quantity it needs, that's a different story and I don't think it's possible at the moment.
sudo chmod -R 000 /*
The nearest I can think of would be the thin client model. One powerful server, low power terminals to access it. All the heavy work is run on the server and the terminal is little more than a remote display and controls. Basically like game streaming, but for the desktop in general. Might not be so good for video or games where you still should use a streaming model. Don't know if there's a unified solution to this.
That's basically it - the thin client model. I've played with moonlight which is streaming for games but I am looking for streaming an entire desktop.
I'm not really familiar with this for a home usage scenario. The systems I've seen are business/large organisation ones, which are used to improve security since data isn't stored at the user. If I were to try doing something similar, for single user, I'd just remote desktop into the server. If multiple user, I'd probably just run a server with VMs on it and remote desktop into the VMs. As said, performance for video or gaming will probably suck. Not sure how sound will work in this situation also...
