Hi LinusTechTips community
I got a question that I need a bit of help with.
I am building a new pc, with an i7-6850k cpu and I will get myself a gtx 1080 gpu (will properly upgrade to 1080ti when it comes out, since I am gaming on a UWQHD monitor).
My question is, should I go for a custom water loop for the cpu and gpu.
Or should I just get a AIO for the cpu and get for example a msi gtx 1080 sea hawk that got an AIO cooler on it?
It will be alot cheaper with the two AIO, so I am curious how much extra performance the custom loop would get me?
I am overclocking. But I have never tried a custom loop before.
If I am going to upgrade the gtx 1080, it will be with a water block on it also. Since I my pc stand in a place where there isn't that much air flow.
Should note that I am not making a build with a glass window in the side, the pc is hide away, so it shall not be for the looks.
Looking forword to your guys advice and help :)
https://linustechtips.com/topic/643167-aio-vs-custom-loop/
Just now, vikingen said:
Custom water cooling never makes sense in a price to performance stand point. I'm not saying nobody should ever do it ever. It's more  of a fun project than a practical one.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/643167-aio-vs-custom-loop/#findComment-8284081
You will get similar performance from the AIO's if you get the right ones and not cheap out on junky cheap ones. Custom loop is honestly 99% show with 1% functionality when it comes to performance over a AIO.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/643167-aio-vs-custom-loop/#findComment-8284105
just get an AIO, its cheaper and less time consuming to do.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/643167-aio-vs-custom-loop/#findComment-8284726
AIOs have shitty pumps. You'll get fed up with the noise eventually. EK Predator is the only exception I've seen (though I'd still only accept a D5 personally). Yet to see the new Swiftech stuff though.
But having said that, Pascal cards really do need liquid cooling. It unlocks a whole new world for them. The difference in boost clock stability is something you would not even believe.
Liquid cooling since 2002.
https://linustechtips.com/topic/643167-aio-vs-custom-loop/#findComment-8287460
