Best perferoming CPU cooler for S340
Gall Cohen
Hey guys, planning on buying a new PC, I have a S340 which I will use with the new parts, I need an air cooler for the CPU.
I'll buy an I5 6600K and will want to OC it a bit, which air cooler would you reccomand?
Thanks!
Budget isn't an issue but I am limited to Noctua, Cooler master, Antec, Arctic, Zalman, Scythe and Thermaltake.
What is your budget?
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
If you're restricted to those brands, then I suggest the Noctua NH-D14.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
Based on the list, your best cooler will be the Notcua NH-D15
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
an NHD15s won't fit in the s340, unless you swap BOTH fans for 120mm.
A NHD14 will however fit.
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
Can you link us to where you're shopping?
I talked to somebody who owns the D15 and it's not comfortable at all, not worth a few degrees.
In the end I will be buying 6700K, I am debating between the D14 and a U12S because I don't want it to be too crowded, what do you think?
I am buying through a site that isn't in English so it will make it harder for you but here:
http://ksp.co.il/?select=.1066..182..2625.&list=1&sort=2&glist=0&uin=0&txt_search=&buy=&minprice=0&maxprice=0&intersect=&rintersect=
Id personally go with the 12s on the s340 due to height clearance, although the 14 would fit (i believe). But super large tower coolers look awkward imo in that case because the top of the case is so "low" compared to other cases
Resist!
If you can spend so much money on a cooler I think it would be better to spend more money on a 6700k or a better gpu :D
CPU & COOLER - INTEL i9 12900K | NZXT KRAKEN X62
MBO - MSI Z690 EDGE
GPU - ASUS GEFORCE RTX 3080 TUF
RAM - 2x16GB KINGSTON FURY 3200MHZ
PSU - PHANTEKS REVOLT PRO 1000W 80 PLUS GOLD
SSD #1 - CORSAIR SN850 1TB
SSD #2 - CORSAIR SN850X 4TB
SSD #3 - INTEL 660p 2TB
CASE - PHANTEKS ECLIPSE P500A D-RGB
MOUSE #1 - LOGITECH G502 X Wireless
KEYBOARD - AKKO 5108B PLUS
SPEAKERS - SVS PB-1000 + 2x ADAM A3X
HEADSET #1 - SENNHEISER IE-300
HEADSET #2 - FOSTEX TR-X00 PURPLEHREART
AMP/DAC - MAYFLOWER ARC
OS - WINDOWS 10 PRO
DISPLAY 1 - LG OLED42C2
DISPLAY 2 - XIAOMI 2K GAMING
PHONE - SAMSUNG GALAXY S23+
I don't think a 60$ cooler on a I5 6600K is that expensive actually but in the end I might get a I7 6700K anyway :) I plan of buying a gtx 1070, a 1080 is a lot more money and i'd prefer to sell my 1070 in a few years and get a new one, while the rest of my system will be strong enough to handle it(hopefuly, future proofing is tricky).
Thanks guys!
Thanks guys!
1070 is just fine. If you aren't doing extreme overclocking pick up the 6700k (much more future proof than a 4 core no hyper therading cpu) and a hyper 212x cooler that should be around :D
MBO - MSI Z690 EDGE
OS - WINDOWS 10 PRO
I've had a NH-D15 in a S340 and it fits pretty easily with the fans lowered.
If cost isn't an issue, get a NH-D15 or NH-D15S. Otherwise, the Mugen Max is an alternative that isn't too far behind: http://ksp.co.il/?select=.1066..182..2625..115.&list=1&sort=2&glist=0&uin=25921&txt_search=&buy=&minprice=0&maxprice=0&intersect=&rintersect=
They're the same height.
He ment the 14S, it's about 165 MM in hight and conflicts with the case, just in this case it's the cooler and not the fans.
I'll also give the Max a look, though I'd prob go for the smaller 12S in the end, as someone said big coolers in smaller cases tend to look strange, also it's performance seemed great!
 I think systems look awkward when there's too much empty space. To each their own.
Agreed to a certain degree, I don't like when a cooler that looks rather dull covers a motherboard or ram sticks that look better, ofc not to sacrifice cooling either and go
with a small tower for an oc'ed chip.
