Hey everyone, what's up?
So I was getting my new PC parts from the shipping service and I went to check my garage for a hidden power supply. I thought I had a spare of EVGA supernova but I found Huntkey MAX 700 something that gives 600w instead of 700 which makes no sense :\. anyway I feel uncomfortable about it and unfortunately there is no PC store near from me that sells an excellent power supply beside a Corsair VS650 Watt. I could buy Corsair AX760 online which gonna take like 15 days to catch money and for shipping but I want to save money for something else and buy it maybe in the next month.
but I wonder, is Corsair VS650 safe to use in my build until I buy another one next month? or just buy Corsair AX760 which its the only way if I had to play the wait game :(.
Here's the build specs in this link:
http://pcpartpicker.com/list/drZXbj
I really want a quick answer as the guy who sells Corsair VS650 is about to run out of stock.
thank you for reading.
https://linustechtips.com/topic/642834-power-supply-suggestions/
If you can afford a 5820K then avoid the Corsair VS. They're cheap shit. Get a RMx or RMi
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8280999
please for the love of all that is good dont get a VS
get this
its cheap, but a absolutely fantastic PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&cm_re=s12ii-_-17-151-096-_-Product
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8281010
@007agentHP @don_svetlio
I could buy a better one, and I know it's cheap.
but the problem isn't about money, it's about time that I can't buy or avoid sadly. I had to wait like 3 months to ship my stuff and other things "I had to build a workstations from my budget as well and I was like crap" but I'm sick of waiting and totally can't hold my self as I really want to test the parts if it's okay and you know? to actually use it and test it for a month at least.
the Huntkey seems broken and I'm afraid to blow things up with it. so I guess I'll play the wait game and take your suggestions, I paid these parts by money and time literally, not gonna blow it up just for a power supply.
@Sakkura
I agree with your point, but do you think it will effect my PC parts on heavy loads or something?
____________________________________________________________________________
I mistakenly posted this topic in the wrong section. sorry about it, there is so many forum sections here and I'm not used for most of them.
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8281070
38 minutes ago, Faris.S said:
@Sakkura
For a month, it'll be fine. It's more of a problem if you used it for a long time at heavy loads. Capacitors might begin to fail, subjecting your other components to higher voltage ripple that could eventually do damage.
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8281301
@GoodBytes
thanks for moving the thread, I appreciate it. :)
___
so after doing a very quick research since I'll have to wait and think, and maybe hold my breath for 15 days.
I checked a good list of tier 1 PSU but I don't know which is the cheaper and the better one for long use.
Here's the list:
Antec High Current Pro Platinum Delta Electronics
Be Quiet
Dark Power Pro P10 / 850w FSP (550w - 750w) / Seasonic (850w - 1200w)
Dark Power Pro P11 850w FSP
Corsair
AX / AXi series 760w - 1200w Seasonic (AX) / Flextronics (AXi)
AX1500i Flextronics
HXi Channel Well Technology
RMi Channel Well Technology
RM1000x Channel Well Technology
Cooler Master V series / V series 1200w Seasonic
EVGA
SuperNova G2 / P2 / T2 Super Flower
Supernova GS Seasonic
Supernova GQ FSP
Supernova PS Seasonic
Enermax DigiFanless 500w Channel Well Technology
Firepower Silencer MK3 1200w Super Flower
FSP
Aurum PT FSP
Hydro G FSP
LEPA G1600 Enermax
Seasonic
Platinum series Seasonic
Snow Silent 1050w Seasonic
X series / X series XM2 Seasonic
Silverstone Nightjar Platinum 520w Seasonic
Super Flower
Leadex Gold / Platinum / Titanium Super Flower
Golden King Super Flower
Golden Silent / 430w Super Flower
Thermaltake
ToughPower DPS-G RGB 1250w Channel Well Technology
Toughpower DPS-G Platinum 1050w Enhance Electronics
XFX
Pro series Black edition Seasonic
Pro series Black edition Limited Edition 1000w Seasonic
Pro series XXX / Semi-Modular Seasonic
XTS Fanless Seasonic
please note it's a quote from tom's hardware from 2015, if you wish to read more here's the link:
http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
@Sakkura
thanks for the information, Sakkura. but I think I should find another deal which gonna be impossible due to the lack of PC stores in my city but hopefully I could find a better one cause I don't want to lose my money and the time I wasted it. if I couldn't then I will decide either I get it or not once I get the cash.
please check the list that I post it here, and if you have a suggestion I'd really appreciate it :)
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8281359
@Thread212
I guess you are right, PSUs aren't something simple as I thought.
I lost my favorite gaming PC that been built in 2012 due to a power supply problems.
so I took your advice and went to find a good online/local store that located close from me and I found few stores that I could trust. I tried to find Coolmaster V series, Corsair RM/RMI and other good PSUs that are cheap to buy and ship, but I just found Corsair AX760 which it was the only option I actually had :( because of the shipping prices that will kill me someday.
I might be an old guy who used to fix and build very old PCs in the past and as the time changes, the Carbide 600Q Inverted was so confusing to install the parts in "especially the fan controller" and the cooler system and other things that I missed in my old life.
Anyway, Thanks everyone for the help, I will share my build experience perhaps when I finish it, and hopefully I'll accomplish my own personal build fully upgraded with a good graphic card that serve my purpose :).
https://linustechtips.com/topic/642834-power-supply-suggestions/#findComment-8295219
