[SOLVED] USB Flash Drive Error: "Please insert disk into E:"
Solved by TechJ,
If you do not need any data try this.
CMD > Diskpart > list disk > select disk (Your number) > clean > select disk (same again) > create partition primary
Windows should then ask you to format it
Hopefully this helps
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
5
5
ken43 ·
Posted in Troubleshooting5 -
8
thedood2k ·
Posted in Power Supplies3 -
2
DARTHDIVIDER0213 ·
Posted in Troubleshooting8
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
