I have troubles with my motherboard, it requires memok to boot up as normally when it boots up it get stuck on "Detect memory" post code and it only can be fix by doing memok. The only temp fix i found was running the motherboard built in function TPII which kinda fix the problems for a while but today it back at it again with memory issues. I have tired updating BIOS which seem to have done nothing, is the problem the memory because running the memory individually or just dual channel i have no problem with it. I had to RMA one of kits because even memok was not fixing the bootloop and it seem like new memory with updated version help for the time being.
Spec:
PCPartPicker part list: http://au.pcpartpicker.com/list/hdRsJV
Price breakdown by merchant: http://au.pcpartpicker.com/list/hdRsJV/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($479.00 @ Centre Com)
CPU Cooler: Swiftech H240-X 90.0 CFM Liquid CPU Cooler
Motherboard: Asus SABERTOOTH Z170 MARK 1 ATX LGA1151 Motherboard  ($429.00 @ CPL Online)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($109.00 @ PCCaseGear)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($91.00 @ CPL Online)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($205.00 @ Umart)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($97.00 @ PLE Computers)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($739.00 @ CPL Online)
Case: Fractal Design Define R5 Blackout Edition w/ Window ATX Mid Tower Case  ($182.00 @ IJK)
Power Supply: Corsair RMx 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($205.00 @ IJK)
Total: $2645.00
Generated by PCPartPicker 2016-08-13 11:37 AEST+1000
Magical Pineapples
https://linustechtips.com/topic/642502-sabertooth-memory-issues/
48 minutes ago, ddswh1pk0s said:
if you already RMA'd one of the kits it could be an issue with one of the slots on the motherboard.
43 minutes ago, Himommies said:
Try putting each stick in individually and see if it posts
If i have dual channel with just two stick on all possible placement and work fines. Single slot also works with no problems. I just have problem when i install all 4 dims.
Magical Pineapples
https://linustechtips.com/topic/642502-sabertooth-memory-issues/#findComment-8277572
