So I'm currently trying to run Arma 3 at 1080 and I'm not gettting very good frames. It seems to not be using a lot of resources. I have an i7 4790k clocked at 4 Ghz and a MSI 1070 Gaming X. They both seem to only run at about 50%. Is there a way that I can sort of force Arma to use more resources to get better frames?
https://linustechtips.com/topic/642271-1070-not-maxing-out/
Just now, LordZanshin said:
Arma 3 is terribly optimized... you use max settings? how are your frames?
Yeah I'm using max settings and I'm getting around 40-50 frames. That's what I would get on my 960 which doesn't make sense because a 1070 is far better than a 960.
https://linustechtips.com/topic/642271-1070-not-maxing-out/#findComment-8275310
A very cpu bound game
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/642271-1070-not-maxing-out/#findComment-8275326
http://www.techspot.com/review/712-arma-3-benchmarks/page5.html
I know it's a lower tier CPU but it clearly shows this is the bottleneck in this game(the CPU)
EDIT; I don't know but since the CPU is only at 50% maybe the game doesn't use all cores to it's full potensial? someone can confirm this?
https://linustechtips.com/topic/642271-1070-not-maxing-out/#findComment-8275343
Arma 3's engine is incredibly CPU-dependent, far more than any other that I know of. I have an older CPU, an i5 2500K @ 4.6 Ghz, and a GTX 1070, and I get ~35 - 55 FPS in Arma 3 (with settings at medium-high). I upgraded my GPU from an R9 280X, and I don't really notice a difference in Arma 3 FPS after getting the GTX 1070.
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
https://linustechtips.com/topic/642271-1070-not-maxing-out/#findComment-8275441
