I've bought a i7 4790 second hand by my friend. I have a 1150 Socket motherboard and a  Titan DC-156M925X CPU Fan which came with my PC. I looked on the website of my CPU Fan cooler and saw this.
http://www.titan-cd.com/CPU_support_list_e.php?id=977
I'm not sure if my CPU would go in.
https://linustechtips.com/topic/642169-cpu-installing-help/
It supports 1150, so it will work
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/642169-cpu-installing-help/#findComment-8274171
yes it will fit on the socket, though it might not have enough power to dissipate the heat generated by your CPU. i think that might be why your CPU is not listed on their site.
https://linustechtips.com/topic/642169-cpu-installing-help/#findComment-8274203
I thought I would have the intel stock cooler but I guess I have the some other brand. Is my current CPU cooler equivalent to the intel stock cooler or is it better?
Here's the specs for my CPU Cooler.
I couldn't find the specs for the intel stock. And would I atleast get under 60 Degrees C? I'm literally not trying to buy anymore parts :\
https://linustechtips.com/topic/642169-cpu-installing-help/#findComment-8274353
