Best, cheapest LED case fans?
TLe6ix
6 minutes ago, TLe6ix said:
Im looking for a case fan that has a blue led and is cheap but comes with good performance. this is what ive been looking at. any thoughts? i currently have 2 stock nzxt case fans
http://www.ncix.com/detail/cooler-master-r4-l2r-20ac-120mm-blue-2e-42176.htm
http://www.ncix.com/detail/cooler-master-jetflo-120-120mm-36-91680.htm
there should be this zalman fan
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
The SickleFlow fans are complete garbage.
I had two of the red LED's ones, and swapped them to JetFlo's. They work several times better. In fact, ~50%+ of my fans are JetFlo's.
  • 2x for the CPU cooler
  • 1x for bottom intake
  • 1x for rear exhaust
Plus, with the LED's inside the fan hub itself, the lighting creates a even glow over the entire fan.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
i did some research on them and it seems like most people who have it say that it isnt all that bright... i found a photo on amazon (link)-https://www.amazon.ca/Cooler-Master-JetFlo-R4-JFDP-20PB-R1-Performance/dp/B00E20SSZ8
ehhh kinda debating, but i want a sorta bright led fan because it will give my case a "under glow" effect as my case is the s340, look at the photos of it on google, you'll know what im trying to go for
Jetflos aren't quiet but they're good.
I don't know about the blue LED version, but the reds are not too bad.
I'll grab a picture of them...
AMD Ryzen Rig
  • AMD R7-5800X
just adding, my case has a blue accent so red leds wouldnt really fit with the blue
9 hours ago, Ichi said:
Get LED strip and normal fans instead...
well.......rather then spend $30 for a fan then buy led strips for another 20, i could just get 2 Corsair Air Series AF120 for $29.00ca together......led strips will come after my build is complete.
