Am I right or (quick question)
A.T
If my cpu got tdp at 91 and my cooler 190 does that mean that my cooler can cool twice as much as I need??
Yes. The tdp of the cooler specifies what the maximum tdp cpu it could theoretically cool sufficiently. That is more than double your needed specification cooler
My PC: I7 4770 (3.4Ghz)
32Gb Corsair Xms3 DDR3
Gigabyte G1 Gaming 980ti
Asus Z87-A Motherboard
Samsung 120gb SSD
Seagate 2TB HDD
Aerocool Xpredator Evil Black
http://www.3dmark.com/fs/8502026
That'd be a crude simplification, yeah. Or you could say your cooler will be half as loud in achieving it's maximum cooling performance with this CPU. Albeit, especially the CPU will vary widely from the TDP. It's only intended to operate at that TDP, but it can be cooler or even hotter in cases.
Does that mean a be quiet pure rock 150 tdp can cool my i7 6700k and even overclocked
Possibly, to air cool and overclock you might need a better cooler, overclocking dramatically increases the heat output so if i were you i'd invest in an all in one watercooling loop for your cpu
Samsung 120gb SSD
Seagate 2TB HDD
when you OC, that TDP goes skyrocketing
Yes.
