OK so i just recently brought a PC with a hard drive and ssd and all the files were pre installed onto ssd so it had little space left its now full from downloading games and now i want to put all non game related files on hard drive and all games on ssd i have copied all windows/user/intel/programfiles/programfilesx86/ect into hard drive where i want them to be is it now save to delete those files from ssd ?? help
https://linustechtips.com/topic/640683-need-help/
what? umm ok if they are saved onto the hrad drive yes most likely
though  recommend just putting games you play on a regular basis to the ssd and probably relocate the location of the downloads documents music pictures that kind of stuff t the hdd if you really want to save space on your ssd
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/640683-need-help/#findComment-8259352
19 hours ago, MasterT8 said:
~snip~
Hi there MasterT8 :) Welcome to the community!
Have in mind that gaming doesn't rely on the storage's performance for anything but the loading times. You won't see any changes in the FPS nor in the graphics when you move your games on the SSD so I'd simply suggest to keep most if not all games on the HDD and keep the SSD solely for applications that you use more frequently and for the OS, leaving some free/unallocated space for caching and over provisioning purposes.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/640683-need-help/#findComment-8263659
