Hi Guys
i reach overclock i5 6600k  4.7 Ghz with 47x multi  Vcore 1.395   stable :-
prime95 27.9   1 hours  pass max Temp 79 C
AIda64 5 hours pass max temp 67 C
Rog Realbench 1:30 hours pass max Temp 71 C
My question what Right version of prime95 for skylake ??  27.9 or 28.9
is my system stable ??o.O
https://linustechtips.com/topic/640541-overclock-advice/
I use occt personally. If it passes 2 hours of that, it should be good. I don't use prime95, I don't trust aida and never heard of rog realbench so I can't make comment on stability. Should be fine though. Try a 2 hour occt if you want to be sure. I haven't had an oc fail that passed 2 hours of occt.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/640541-overclock-advice/#findComment-8258128
1 hour ago, Neo_amro said:
Hi Guys
You want to test every drop of processing power your CPU has? Then you gotta use 28.9, as 27.9 doesn't make use of FMA3 for increased performance. If you want to call your system truly stable (which is a thing you can never guarantee), it has to survive anything your throw at it, including P95 28.9.
Also, an overnight 8h test to help "assure" stability is usually recommended as well. 1h is nice, but I've had my fair share of OCs that fail much later than that.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/640541-overclock-advice/#findComment-8258188
