http://pcpartpicker.com/list/XLLkXH grab a after market cooler for your gpu and a better PSU
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/640311-first-buld/#findComment-8255716
15 hours ago, m2234323 said:
how do  I deal with static electricity
Just touch something large and metal occasionally. Static isn't really an issue anymore, I built a pc without static protection on my bed. So I wouldn't worry too much but just touch metal occasionally just to be safe.
https://linustechtips.com/topic/640311-first-buld/#findComment-8259022
21 hours ago, m2234323 said:
I have order the part for my fist buld
http://pcpartpicker.com/user/m156789/saved/kxDbt6
how to find a good video that linus did to wath that show step by step
upgrade to a gold power supply will pay for itself in a year. m.2 ssd even with sata standard is a good idea relatively the same price without the fuss of the cables. try and go with an asus board if you can especially if your going to be overclocking. also you can maintain the same cas latency with your ram and get a higher frequency at that price point and preferably gskill. i think most will agree. let me know what your thoughts are
https://linustechtips.com/topic/640311-first-buld/#findComment-8260327
um the parts aready order for it and are on the way
https://linustechtips.com/topic/640311-first-buld/#findComment-8260361
yes i didnt notice lack of cpu cooler. leave the gpu alone unless sound is an issue but definitely cpu cooler of course
https://linustechtips.com/topic/640311-first-buld/#findComment-8260366
how interesting I will have ups and fed ex delivery the parts in 4 box over 4 day is that normal
 how may box did you get  for your bulds
and it do come with a stock cooler
https://linustechtips.com/topic/640311-first-buld/#findComment-8260380
newegg usually throws it all in one box except for the case a build comes in 2 boxes
https://linustechtips.com/topic/640311-first-buld/#findComment-8260386
 I am order it from 3 site
newegg just the ram and gpu
amazon cable case and ssd and power supply
superbiiz cpu and montherbord
and I saw anywhere from tomorrow for one pice to sat
how intrest the case will get here the in one day and it just left some hour ago
https://linustechtips.com/topic/640311-first-buld/#findComment-8260416
damn looks like you min maxed the prices out like a beast! i should hire you to shop for me lol :)
https://linustechtips.com/topic/640311-first-buld/#findComment-8260423
what do you do when you order
and wow I did not know that ram and gpu is so heavy like 4lb
do I start when it show up or waite for all the pice to show up
and I still mange to go over my buget by 100$
https://linustechtips.com/topic/640311-first-buld/#findComment-8260444
probably mostly packaging. i usually put it all together on newegg because their search functions cover all the obscure parameters like cas latency and other things for other components. im sure there is some price difference but i could spend that extra time i spent shopping and go out and make some more money ;) lol
https://linustechtips.com/topic/640311-first-buld/#findComment-8260464
https://linustechtips.com/topic/640311-first-buld/#findComment-8260471
