Hello guys
im upgrading my case to the Phanteks Evolv ATX Tempered Glass edition and i also seek to update my fans
For the exhaust fan i am looking at the Thermaltake Riing 14 RGB and for my radiator i'm looking at the new Corsair ML Fans or maybe the Riing 14 RGB too
Also i noticed that Riing and the Corsair ML ones are not PWM? would that be an issue?
What are your thoughts? I kinda looking for a pair to replace the current stock ones, they are very loud
(please, no noctua recommendations, those fan colors are just bad even the black ones!!)
https://linustechtips.com/topic/640259-fans/
I do not have any experience with those fans so I can't tell you about performance vs noise levels.
I looked them up and they are both controllable through PWM. The TT Riing fans are controlled by their own controller included in the 3 pack solution.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/640259-fans/#findComment-8258126
Are you referring to the stock case fans being loud or the rad fans?
https://linustechtips.com/topic/640259-fans/#findComment-8261160
3 hours ago, reystar said:
The stock radiator fans that came with the Corsair H110i GT
Riing fans are decent. I'm reserving any advice on the new ML fans until more reviews and benchmarks are out.
https://linustechtips.com/topic/640259-fans/#findComment-8264784
