Just as the title says, im looking for a low power GPU with a blower style cooler, i searched for a 750ti (one of the lower powered gpu's i could find that can somewhat play the games i plan to play) and for a 950 but i have not found one yet.
Does anyone know where i could find preferably one of these GPU's with a blower style cooler? (or if i could even just buy the cool separate from the GPU?).
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/639119-lower-power-blower-style-gpu/
8 minutes ago, Shd0w2 said:
What's your budget to spend on it? I'm guessing around 950 to 750TI price range then,
There is no budget really, just looking for something that fits in for what i am looking for, low power requirements, can play games, and has a blower cooling. Now when i say "can play games" only a few i plan to play are actually GPU intensive so for example, the 750ti i mentioned would work fine, my main concern is the low power consumption but can still play a game such as Total War Warhammer as Medium or higher settings. To answer your question, $300 i guess? (just to let you know, a GPU's such as the gtx 970 which is more power efficient than a 780ti or something is still a little much for what i am looking for).
Edited by Made In Canada
Words
-Made In Canada
Why do you need a blower cooler. A rx470 is probably as low end as you will get.
This specific build would be a ITX build with low power consumption as a main part of the build, because the PC would be ITX if it was built, a GPU with a blower style cooler would be better. The GPU you mentioned does have a blower style cooler but the power consumption is way to high for what i am searching for. At this point, i am just going to plan to build the PC with a GTX 950 75W open air GPU from Asus. Thank You very much for searching however, it is appreciated.
-Made In Canada
15 minutes ago, jhurst117 said:
well the rx 470 did just launch might want to look into that
At that point, i should just get a GTX 1000 series card. The GPU you mentioned does have a blower style cooler but the power consumption is way to high for what i am searching for. At this point, i am just going to plan to build the PC with a GTX 950 75W open air GPU from Asus. Thank You very much for searching, it is appreciated.
-Made In Canada
