New cooling help!!!?!?!!!!?!?!?!
So I am going to upgrade my case and cooling system with a new system.
I want to know if these products are everything I need and what parts are best for parts I don't have already.
The case I will be getting is the In-Win 303
https://www.overclockers.co.uk/in-win-303-midi-tower-case-black-ca-073-iw.html
CPU Cooler
https://www.overclockers.co.uk/raijintek-tisis-dual-element-extreme-cpu-cooler-hs-008-rt.html
with this for the rear fan slot
https://www.overclockers.co.uk/demciflex-dust-filter-120mm-square-black-black-cm-007-df.html
Rest of PC
https://www.overclockers.co.uk/cooler-master-12cm-sickleflow-green-led-system-case-fan-cm-r4-l2r-20ag-r2-fg-012-cm.html
and 1 of these
https://www.overclockers.co.uk/demciflex-dustfilter-set-for-360mm-radiator-black-black-cm-034-df.html#
What I want to know is if this will all fit in my case and yeah also if this is everything that I need and I haven't missed something out?
https://linustechtips.com/topic/639054-new-cooling-help/
49 minutes ago, Alexzz_ said:
you have a radiator but nothing else listed for a water cooling build?
yeah i got misinformation from a friend that i needed a radiator. due to the fact at first i was originally going to post this with 2 options. 1 being with a water cooled aio system as well as the 3 fans so eyah
https://linustechtips.com/topic/639054-new-cooling-help/#findComment-8242871
Case fits 160mm coolers. Rajintek is 166.5mm, not going to fit. This fit or not is quite simple. Most cases list maxinum height for CPU coolers on their own product page (google case model). Some like Corsair have few mm to spare, but in general you want exact that or under. Coolers list their dimensions on product page also (again google model name). D14 is 160mm if you want dual tower. Or you could go for any 120mm single tower.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/639054-new-cooling-help/#findComment-8245864
just wanted to ask quickly. Is there a way of getting the d14 without the brown fans that it has on it. Don't really like the colour of them and would personally prefer to switch them out for these - https://www.overclockers.co.uk/cooler-master-12cm-sickleflow-green-led-system-case-fan-cm-r4-l2r-20ag-r2-fg-012-cm.html
However if the fans provided in the cpu cooler are actually better fans and will make a big difference then I won't worry but yeah was wondering if there would be a way of getting them without the fans provided.
https://linustechtips.com/topic/639054-new-cooling-help/#findComment-8256043
It comes with fans. And if you don't like color, then its better to look for another options. Noctua coolers are best as package.
If you want dual tower still, this is only good one I found on PCPP https://pcpartpicker.com/product/3XXfrH/deepcool-cpu-cooler-neptwinv20
Another good pick, but single tower is https://pcpartpicker.com/product/Ztp323/cryorig-cpu-cooler-h5ultimate
https://linustechtips.com/topic/639054-new-cooling-help/#findComment-8256113
It comes with the fans and a large part of makes the cooler so great are the fans. If you don't like the color, I suggest to get a different cooler to begin with.
Sickleflows are mediocre at best and much worse than the included NF-P12 and NF-P14.
https://linustechtips.com/topic/639054-new-cooling-help/#findComment-8261740
