Hi guys, I have i3 2120 and gtx 1060 along with 8gb of ram. 2 weeks ago I used to have gtx 650 ti. I play CSGO most of the time. My fps on high settings at 1080p would be around 150 on average. Now even upgrading to gtx 1060 i am getting same fps. I know that my i3 bottlenecks but sure it's not that bad. What's causing this? I have tried lowering down the settings and the fps would be same. Or on highest settings still same.
https://linustechtips.com/topic/638971-csgo-fps-problem/
Your i3 is a terrible bottleneck. i3s are shit for GPUs like the 1060/480
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241288
Just now, sarfraz said:
I know but my friend is using i3 4130 with gtx 660. He is getting >200 fps. I know there isn't much difference between i3 2120 and i3 4130.
i3 4130 is 40% faster than your i3 2120.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241302
4 minutes ago, Archarin said:
Really the only explanation is a hardware bottleneck somewhere if it's pretty much the exact same. It would be helpful to list the rest of the parts.
If i3 would be a bottleneck then games like witcher 3, battlefield 4, fallout 4 would also run on low fps. But they are running on ultra. My other specs:
HDD: 1tb 7200rpm
PSU: corsair VS 450 watts
Asrock h61m-vs3 mobo.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241305
HDD: 1tb 7200rpm
1 - your PSU is utter shit
2 - you have a bottleneck because CS:GO needs a LOT more CPU horsepower than GPU horsepower. You are also getting bottlenecked in those games, am 100% sure of it.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241309
Well I don't think so.
Well what you think doesn't matter. Facts state otherwise. Ivy was 15% above Sandy, Haswell is another 10% on top of that. Add in clockspeed differences - you're looking at 30-40% more from the Haswell i3.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241314
PSU is just fine. and even with the bottleneck I shouldn't be getting same fps. Try to understand. The other games like witcher 3 would run on 10 fps on ultra settings with gtx 650 ti but now it runs at 50 fps.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241317
I think a CPU + PSU upgrade is the best here. :)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241321
50fps is low for a 1060. You should be getting 60-70 in that game. And what you are describing is the very definition of bottleneck. Your i3 was bottlenecking the 650 Ti in CS:GO as well.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241328
I know. I am gonna upgrade to i7 6700k in 2-3 months. But PSU is just fine.
Corsair VS are low-end office units from CWT. They are not capable of SAFELY powering a system with a 6700K and 1060 in a warm environment.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241332
Csgo is incredibly cpu intensive if you open task manager youll probaly see 100 percent cpu and like 45 percent Gpu
My life
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241333
hmm. Now I get it. You mean to say that i3 with gtx 650 ti was bottlenecking in csgo too. OK. So this makes me sad. I have to upgrade my cpu.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241339
HDD: 1tb 7200rpm
Those games are much more graphically intensive so a CPU bottleneck is less noticeable. In CSGO the GPU is able to put out a really high framerate since it's not that hard to create each frame. In situations like that the CPU becomes the limiting factor as it can't serve up information to the GPU quick enough.
If you wanted to see the bottleneck on those other games you'd need to set everything to the lowest settings graphically and then test each GPU.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241341
Erm I think it can manage but you are pushing it a bit hard... :(
Edit: For CS:GO a i5-6600K is gonna be overkill.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241342
PSU first. Check with @STRMfrmXMN 's whitelist. The VS series are low end junk and not suitable for a rig like yours. They are meant for office PCs and word processing, not gaming.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241347
I can't find VS series there. It's not mentioned. I want a solid proof before upgrading.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241362
Exactly. VS are NOT good units. Just ask him or @Aniallation. He also had a Tier list and the VS were at the very bottom of the PSU tier list. Something like a SeaSonic M12II EVO or Antec High Current Gamer would be a good upgrade. They are modular and affordable. 520W is all you will need.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241370
SeaSonic M12II EVO is affordable. I can't find the Antec one here in India. But Seasonic seem to be good deal. When I will upgrade, I will buy this too.
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241404
I think corsair should discontinue their cx and vs lineup. Newbies are like 'omg that's a corsair psu for so cheap since it's corsair it should be really good' and fast forward 2 years their house has burned down
if (you want to reply) {
 USE THE QUOTE BUTTON
else {
 DONT
https://linustechtips.com/topic/638971-csgo-fps-problem/#findComment-8241412
