Today I upgraded from a low-end air cooler to a Corsair AIO CPU cooler. I'm OC'ing my 6700K to 4.6GHz. My question is this: Is there a way I can set the CPU to perform at this speed all the time, even while not under heavy load?
Also, my mobo (Gigabyte Z170X-UD3)  only showed a preset OC option up to 4.6GHz. Is there any way I can try higher clocks? What are you guys able to get on a 6700K OC'd?
https://linustechtips.com/topic/638666-keep-oc-cpu-speed-always/
disable all power saving features (C states...) in bios and go to power options in windows and use high performance profile.
https://linustechtips.com/topic/638666-keep-oc-cpu-speed-always/#findComment-8238390
