Are you saying your OS is 32-bit?
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/638591-ram-problem/#findComment-8237518
5 minutes ago, Hahzi said:
32-bit OS can't use above 2GB. You have to upgrade to 64-bit. Nothing you can do, limitation of the OS. Sorry mate :/
https://linustechtips.com/topic/638591-ram-problem/#findComment-8237568
Apparently they can use up to 4GB
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/638591-ram-problem/#findComment-8237630
Ah that's right, my mind slipped xD still won't be able to use the 8GB regardless and most games require 64-bit, so it's worth the upgrade still.
https://linustechtips.com/topic/638591-ram-problem/#findComment-8237699
