I need a Xeon processor for under $10. Preferably with respectable performance, albeit not necessary though. It needs to fit in a LGA 1151 socket. It is perfectly fine if it is used; moreso than not.
Motivation is where, and what you make of it.
“It is relatively unusual that a physical scientist is truly an atheist. Why is this true? Some point to the anthropic constraints, the remarkable fine tuning of the universe. For example, Freeman Dyson, a Princeton faculty member, has said, ‘Nature has been kinder to us that we had any right to expect.'”  Albert Einstein
https://linustechtips.com/topic/638568-need-recomendations/
Then remove the socket requirement.
https://linustechtips.com/topic/638568-need-recomendations/#findComment-8237204
The only xeons you will find under $10 are lga771, 1366, or 1567 or possibly even older ones then that.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/638568-need-recomendations/#findComment-8237206
You can find 1366 cpu like the w3530, or w3550 for under $15USD, a non-oemmotherboard x58 motherboard is about $100USD though.
This is the case for pretty much any older xeon with respectable performance; the cpus are cheap, the motherboards are expensive.
https://linustechtips.com/topic/638568-need-recomendations/#findComment-8237250
