Just now, TristanJ said:
I just got a new i7 6700k and a h100i extreme as a cooler and while I was stress testing the temps was jumping between 70C and 40C every few seconds. Why is that? I included a picture if you wanted to see.
Load is constant while this happens?
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237173
4 minutes ago, TristanJ said:
Yes Intelburntest constant 100% When it dips lower and stay there that when the test is done
Is it throttling for some reason? Is the speed staying constant?
Perhaps your cooler is changing itself from a quiet preset to a performance preset?
Also, can you check with HWMonitor?
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237203
4 minutes ago, LeapFrogMasterRace said:
I think I need to reapply my thermal paste because my temps are really bad but I ran it quickly to prove my point.
Yea it seems like you are correct. I reran the test at Max and it no longer did this. The temps went up to 80C in like 5min is this too high for a AIO watercooler? Since I am not confident in my thermal paste apply skills.
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237254
What voltage are you running at?
It's pretty hard to mess up thermal paste unless you barely put any at all or covered the whole thing with it, so you're probably fine there :).
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237268
I am not sure but I did not change it from stock
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237272
Oh so it's probably running auto. It often overestimates how much you need. I'd try setting it to manual. What's your multiplier?
80C is a little higher than preferable for constant temps - the occasional spike might be ok, but not as much just sitting there.
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237288
That was running at full load it idles at 20-40c
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237294
Yeah I know. But under a stress test I'd try to keep it around 75C at the most. 80C won't fry it, but if you can get it lower, it's better.
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237299
Hmm how can I improve the temp?
I'd try controlling the voltage manually first. You can probably get it lower than whatever auto is doing - should help a lot. Other options are to lower the multiplier by 1, make sure fans are going 100%, increase water pump speed (if possible).
I'd do voltage though, most effective and best in the long run.
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237323
Perhaps one of the fans on that H100 is dead or the pump is running (way) too slow. That wouldnt explain the jumps but it would explain the generally high temps
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8237372
Bumped the cpu core clock up by .2 ghz and is raised the temp 20C didn't change the voltage now it is not performing as well. I think its faulty temp sensors on the motherboard. because the fans will randomly ramp up and the mobo underclocks the cpu yet it reads temps of 43C at max under load. but it will boot from a cold boot into 30C and be at 40C in under a second which isn't possible. Another thing is its water cooled and the cooler is tightened all the way it has a stopping point. but temps will shoot from 27C to 50C randomly and sometimes it'll go read 6 ghz on turbo boost when the turbo clock is 4ghz. I am probably never buying gigabyte or AMD again unless someone knows how to fix it.( All the temps and clocks after the first sentence are at stock settings after the oc damaged something further somehow. Also this is a new system.)
https://linustechtips.com/topic/638567-cpu-temps-jumping-around/#findComment-8238127
