Hi guys. I got a lot of help from tou guys to choose a part for a computer. I'm going to the Micro Center to buy all of my parts. Buy my parents are keep asking me that what am i going to do if i fail to build my gaming pc. So i looked up the micro center and they said they build custom pc. Is that mean they will build a pc with parts i bought? If it is could you guys tell me how much it will cost? Thank you
https://linustechtips.com/topic/638263-help/
Don't worry about failing to build it. They're so hard to mess up nowadays. And if you do, people like us can help!!
How much are you looking to spend on the PC?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/638263-help/#findComment-8233603
It depends on how much time they will spend on building your PC. If it's a $5000 watercooled computer with RGB lighting, they will certainly spend a lot of time on your PC (In germany, they take about $60-$70 an hour). I would just build it by myself.
i7 6700k - 32GB DDR4-2133 - GTX 980
https://linustechtips.com/topic/638263-help/#findComment-8233606
My pc cost little less than $900. Its without os
https://linustechtips.com/topic/638263-help/#findComment-8233623
24 minutes ago, Lolucoca said:
I would really build it myself. If you decide to let them build it, factor a cost of $120-$200 in.
Okay i was concerned about after building like installing os and downloading drivers and changing setting to play games. I think i will build it myself thank you
https://linustechtips.com/topic/638263-help/#findComment-8233786
Even if this computer store built it for you, since you don't have an OS, you would have to install all this stuff anyways. It's not that difficult. :)
https://linustechtips.com/topic/638263-help/#findComment-8233831
