So I built a new gaming/workstation PC the specs are
xeon e5 1650 3.2 GHz 12 MB cache 6 cores 12 threads
16 GB Ram
a single Sapphire nitro RX 480
so i wanted to invite my cousin over now i sold him my old laptop that had an Intel core i3 350m 2GB ram Intel hd graphics 1366*786 60 Hz display of course this isn't a gaming laptop by any means
so i wanted him to bring it over to my house and then i would make a virtual machine using virtualbox with windows 10 8GB ram 6 threads and then make him remotely control this machine from The Laptop so we can play minecraft together using LAN multiplayer and overwatch
however there are some problems with this :
first of all i want the virtual machine to use exactly half of the resources of the host i did this with the ram and CPU but i don't know how to do it on the GPU since in virtualbox you can only select the amount of vram so i don't know if this is going to make it like i have two 4gb RX480s or not then i want to know do i just install AMD Drivers or guest addition drivers note that i want both host and machine to give roughly the same gaming performance and if there are any other virtual machine creator that supports what i want better then please tell me
then i want to know the best free remote server to install on virtual machine for minimum latency on the same network and i want it to support all versions of DirectX and vulkan and opengl or most of them at least
thank you
https://linustechtips.com/topic/638198-remote-pc-gaming-using-virtual-machine/
You best way to do this is using hyper v and remote FX. Hyper-V is a type 1 hypervisor and better than virtual box. You will probably be limited to dx9 and opengl 2.1 and 1gb of vram. THen use steam in home streaming.
Unless you buy a grid gpu and run xen/esxi there is no way to do this well.
I was under the impression you couldn't share the gpu and needed 2.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
with the xeon i bought there was an nvidia Graphics card however its a workstation one i am not sure about the exact model but since its a workstation it won't be a good gaming so can i use this and by any magical way be able to share the other GPU ?
