Using 2 wireless networks at once.
With two adapters, yes.  Though I am not sure if you will get the combined performance.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
You mean use both of their bandwidth for faster performance on a single network? It sort of depends on the way your wifi router works i think. But I don't know if a computer program could do it.
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
Well, my router is weird about it. Either you can connect to the 5g network or the 2.4g network. One or the other. They literally both show up as two separate networks when you try to connect to wifi.
Yeah, Linus did a video on that. Look it up. i don't think it can work, but i have wondered about it a lot.
16 minutes ago, Knaj said:
Would it significantly increase my speeds?
If you have only one dual band router, which of course means you are subscribing to a single ISP service, the overall internet speed will not improve.  A 100Mbps Internet connection will remain 100Mbps, it wouldn't become 200Mbps because you double your connection to the same router/service.  What might improve is your connection between only the router and computer.
But if you had two routers, each with its own ISP service (or a single router that supports connecting to multiple ISP services), you might be able to get a performance boost either through bridging the connections or some type of bonding.
