usb Car player doesn't read USB stick
Solved by Naeaes,
Try cleaning it with diskpart and then reformatting.
Open command prompt as admin, type DISKPART, type LIST DISK, judging by the capacity, pick the stick by typing SELECT DISK [number], then type CLEAN. Type EXIT to exit diskpart and type EXIT to exit cmd.exe to seem like a pro. You can use diskpart to format the stick too, but it's way easier in the GUI.
