Hello.
I recently built a £155 PC for my friend with a Sapphire Dual-X HD 7970 and a xeon X5450. My friend was considering upgrading to a gtx 780 but I talked him out of that one as buying one to upgrade from a 7970 isn't worth it, even without that CPU. What Platform and CPU should my friend upgrade to? I am thinking X58 and a xeon X5640 or X5650, or lga 1155 with a 2500 or 2500k
Please bear in mind I would be doing the upgrade and I would buy my parts used, so an Athlon X4 860K or Pentium G3258 isn't what I'm after
Thanks in advance
https://linustechtips.com/topic/637962-cpu-upgrade-for-7970/
I would go for X5650, 2500k isnt enough anymore, but some games that just use 2-4threads can have poor performance.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/637962-cpu-upgrade-for-7970/#findComment-8230563
Those Xeons use the same lithography as the 2500k and has a much lower clock. So it seems to me that the single-threaded performance would be much better on the 2500k.
However, it looks like the X5650 can be overclocked easily! So if you are willing to spend the time getting it as high as possible, then that is clearly the better choice! Think about all those cores at 4.5Ghz! Those 32nm CPUs still work great today with aggressive OCs on them.
https://linustechtips.com/topic/637962-cpu-upgrade-for-7970/#findComment-8230675
OK, I'l suggest that to him. I will probably give him one of my old cases and watercool the CPU. He has a budget of around £200 so that would work.
https://linustechtips.com/topic/637962-cpu-upgrade-for-7970/#findComment-8230724
http://cpu.userbenchmark.com/Compare/Intel-Core-i5-2500K-vs-Intel-Xeon-X5650/619vsm355
The 2500k is better then a 5650k for gaming, you already lose most of the performance of the 5650 as no games will use more then eight threads currently. So unless this is for rendering or something that can use the threads the i5 is better.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/637962-cpu-upgrade-for-7970/#findComment-8230860
