Need help deciding between two SSD's!
Solved by WoodenMarker,
Unless you need the extra speed, go with the cheaper drive.
The main benefit of getting a ssd which is the random access times and read speeds won't be hindered by sata 2.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
