LED strips
Go to solution Solved by LordMastodon,
Just now, M9shaboi said:
but the one i have looks so small and the one in the computer looks so big O,o so there has to be sized as i see it hehe but i'll take a look to nearest computer store
Yeah, you should probably take the LED strip and a picture of the connection in the computer to the store, just to make sure you buy the wrong thing. The LED strip may be using a slightly different connection, but you should be fine.
tzF7xosiF_LqRfNR3pBBPG9EoPjeeIvEzQ1fBbQSEzAsrhBi0T4fSOujcN0lwC2tDu_dbHz7JKKFMl8P
DIDNT KNOW WHERE TO PUT THE THREAD but it has some relations wiht PSU i guess
ok i bought some led strips from WISH ( dont question why ) then i got this, was like what? so i open my computer then realise the 2nd molex looking one with no pins sticking out, didnt have any pins so what am i suppose to do? how am i suppose to connect it to the computer?
https://linustechtips.com/topic/636753-led-strips/
Your pictures aren't showing up, and giving what I assume is some context to your post.
I will most likely not respond to you in a thread unless you quote me.
$500 PC | $800 PC | $1000 PC | $1200 PC | $1500 PC | $2000 PC | $2500 PC | $3000 PC | $4000 PC
Damnit Carl (My portable POS):
CPU: Core i7-6700HQ
Motherboard: Toshiba L55-C5392 Mobo
RAM: 8GB DDR3 (even though I have Skylake)
GPU: Intel HD Graphics 530
Case: Toshiba L55-C5392 Case
Storage: 525 GB Crucial MX300 SSD
PSU: Whatever power jack comes with it
Display: Some 1366 x 768 garbage + an OK 1080p monitor
Cooling: Not enough + an external laptop tray
Keyboard: The included one
Mouse: $4 Lenovo 3D Optical Mouse (not as bad as you (rightly) assumed)
Sound: The Skullcandy branding right under the power button should clue you in
Operating System: Windows 10 Home
PCPartPicker URL: pcpartpicker.com/i-wish-i-had-enough-money-for-a-desktop-my-laptop-is-so-sh*t-its-not-even-on-portablepicker
https://linustechtips.com/topic/636753-led-strips/#findComment-8217034
really you dont see them? i can see them?
I do not see them.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217069
ok let me repost them quickly i'll try using puush this time
Try using the attachment system this time.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217074
27 minutes ago, M9shaboi said:
Not signed in
Not signed in
Ah, there we go. I see them now.
That second picture doesn't really look like Molex to me, is there an instructions manual that came with that? Also, would you happen to know what model they are?
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217098
Dont know the model of them as i said i bought from Wish so i just picked out one but in the last picture the one to the left that's the thing i dont understand how i should plug it in to the PC its all i need to know or else i got everything covered up
Is that big white thing to the left of the wheel related? If so, can you take pictures of both ends?
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217123
10 minutes ago, M9shaboi said:
it works but only red and green and nothing else like fade flash etc so i need to connect the other molex with with no pins sticking out but i have no idea how to
Maybe you could find a female to male Molex adapter?
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217176
what's that? and btw can't i cut it out and just pit the wires in a molex one in my case? with no pins sitcking out
Sorry, I meant to say male to male Molex adapter. It's essentially a wire that has Molex with "pins sitcking out" on both sides. You could look at one of those.
Please don't cut it out, that's extremely ghetto and the odds of it working to begin with are low, not to mention the odds of it working for any sort of extended period of time.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217199
so if i get male to male the only thing i have to do is connect the molex to a female molex ( no pins sticking out ) in to my case and get the one iwth pins sticking out to my led strips correct? but aren't there diffrent sizes etc?
https://linustechtips.com/topic/636753-led-strips/#findComment-8217208
Precisely. No, there are not any different sizes to Molex, as far as I know.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217214
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8217226
You will require a molex to DC barrel adapter, I have a guide here under Power RGB LED's which goes over making a connector, you can also purcahse theses online:
https://linustechtips.com/topic/636753-led-strips/#findComment-8219493
OK, OP, take note of that. He's right. You'll also require a Molex to DC barrel adapter.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/636753-led-strips/#findComment-8219502
