So this has happened to me 2 times now. I bought a GTX 970 Strix on a really good sale. (About 250 Dollars) And It worked perfectly. Then a weird sound started comming out of the fans. It was like bad bearing. So I asked from a warranty. And I got a brand new one. Well that sound is back. I wonder if anyone gets it aswell. It is not the normal fan noise.
Any has had this problem and have any tips?
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/
Contact the warranty again.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/#findComment-8215958
1 minute ago, Chandres said:
Not best audio quality
well its rma time again then. thats far from normal.
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/#findComment-8215965
I believe that some Asus cards have problems where the fan or LED wire hits the fan. Try to see if anything like that is happening.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/#findComment-8215993
Like @Flavortown2k16 it sounds like that fan isn't too happy.
I kinda hope the user serviceable fan thing catches on because the programs by XFX and Sapphire to allow for user replaceable fans sounds really promising. Though it might be awhile before we see how well this idea will work.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/#findComment-8215994
13 hours ago, FilipSebik said:
Try putting them at 100% speed and 50% and changing that rapidly before you RMA it. It might fix the bearings if the lubrication for them didn't spread or stuck. I fixed my Jetflo and Venturi HF fans
no fucking way. That Worked. Not it's quiet as fuck. Thanks
https://linustechtips.com/topic/636664-help-with-gtx-970-strix/#findComment-8219717
