Best 4k for the value, I also want to have thin bezel.
-size
I would like about 28 inches or greater, but I could do with less
-budget
I would like to spend about $300 or less, but I would spend up to $450
-input type
I'm not sure, feel free to enlighten me
-variable framerate technology
-location
Game room
-panel type
I can tell you that I care more about color quaity than refresh rate
-refresh rate
At least 60
https://linustechtips.com/topic/636558-best-4k-for-the-value/
I wouldn't recommend going 4k at that price point. There are a lot of compromises when you go there. If you really need 4k, then the AOC U2879VF seems decent for $300. Personally I would rather get a decent 1440p monitor, like the Asus PB278Q.
https://linustechtips.com/topic/636558-best-4k-for-the-value/#findComment-8214847
I have a friend that recently purchased a AOC U2879VF 28". He payed $320
http://www.newegg.com/Product/Product.aspx?Item=N82E16824160278&cm_re=AOC_U2879VF_28"-_-24-160-278-_-Product
It's $300 on newegg right now.
Colors are decent enough, it's not IPS but the colors aren't washed out, they look right. For $300 you are not getting anything better.
https://linustechtips.com/topic/636558-best-4k-for-the-value/#findComment-8215000
