first custom PC, need advice
http://de.pcpartpicker.com/list/D9q8M8
This build should do you nicely. and comes with NVME M.2 drive (256). If there is some reason you don't want that now, or really want yout 500GB 850 EVO, they cost about the same and you can just get the other instead.
For CPU I got your the 6500 to save a bit of money. You could and should get the 6600 if you want to pay a bit more for a bit more headroom.
for the CPU cooler, your 6500/6600 will come with an intel cooler in the box. Since you're not overclocking, this cooler will do a decent job of keeping your computer cool. If you really want an aftermarket cooler anyway, you could get something cheap like a BeQuiet! Pure Rock or a CoolerMaster Hyper 212 EVO. There are cheaper ones, but those often won't be all that much better than a stock intel cooler.
Motherboard I chose because its H170, has USB 3.1 type A and C, M.2, great audio, good features, and all around a good board. Not terribly expensive either. If you want something else, then by all means go for that instead.
RAM is RAM. get what you want. whatever you think will look good.
for storage I chose a 256 GB NVME drive since you were saying you want one and its about the same price as the 500GB storage SSD you had selected. If you really need that 500GB storage, you could stretch your budget to get the 512 NVME drive (its only about 125 more) or you can just choose to get your other SSD instead.There is also the OCZ RD400 series NVME drives that are M.2. If you can get them, they may be slightly cheaper and have similar performance levels.
Allocated 300 for your choice of GPU. That should be reasonable based on your pricing in your first post. Get a 1060 or 480 8GB. the 480 4GB version is not ideal for powering multiple monitors.
PSU choice is for decent quality and price. to keep the budget down. There units with more wattage, and there are units with better quality, but they cost more in order to get there. the PSU I selected will do good in your system with those components.
If you feel you want something bigger or better, this is a great choice for the money: http://de.pcpartpicker.com/product/3pqdnQ/xfx-power-supply-p1550gts3x
Left your case selection empty since you have already decided upon your own case, and chose the same wireless adapter for you assumming you chose that one for a reason. Enjoy the build.
