Try disconnecting some of your fans one by one to rule that out.
CPU || Ryzen 2700x @ 4.3ghz  Motherboard || ROG Strix B450F  RAM || 16GB TridentZ 3600 B-Die  GPU || ASUS ROG Strix 1080Ti  Case || Thermaltake V71 RGB  Storage || Intel 760p 240GB + Intel 535 480GB SSD + 1TB WD 7200RPM HDD  PSU || Corsair HX850i  Cooling || Corsair H110i GTX  Keyboard || Corsair K70  Mouse || Logitech G502 Proteus  Sound || Bose Companion 5  Operating System || Windows 10 Pro
https://linustechtips.com/topic/635907-loud-noise/#findComment-8207618
3 minutes ago, Electronics Wizardy said:
you don't have a external hdd or any computer?
Do you care about the data. If you don't you can rma the drive and get a new one, but you will lose all your data.
It's a new pc I bought though that's the issue. I sold my old pc for this
https://linustechtips.com/topic/635907-loud-noise/#findComment-8207660
Do you care about the data?
If you don't then return it.
If you do, but a external hdd and use ddrescue on a bootable use to make a image of the drive.
https://linustechtips.com/topic/635907-loud-noise/#findComment-8207663
If I were to replace the hdd will it be fine?
https://linustechtips.com/topic/635907-loud-noise/#findComment-8207677
