so i am about to build a new pc with a 6700k which i believe has 20 pcie lanes, in the build will be a gtx 1080 that i believe uses 16 lanes then a samsung m.2 ssd that uses 4 lanes. total 20 lanes used. i also wanted a xonar essence stx sound card in the build. will the effect performance on any of the other components and if so how? please explain to me somebody :S thanks
  • CPU
    Intel i7 6700k
  • Motherboard
    Asus Maximus Formuula VIII
  • RAM
    16GB Corsair Vengeance DDR4
  • GPU
    Asus Strix GTX 1080 ti
  • Case
    Be Quiet Silent Base
  • Storage
    256GB Samsung Pro M.2 SSD and 2TB Samsung SSD
  • PSU
    Corsair AX860
  • Display(s)
    Asus Rog Swift pg279q, 165Hz IPS
  • Cooling
    Be Quiet Dark Rock 3
  • Keyboard
    Razer Huntsman Elite
  • Mouse
    Mionix Castor (waiting on stock for the G Pro Wireless)
  • Sound
    Asus Xonar Essence stx, Audioengine A5+, Sennheiser HD650
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/
The GPU lanes are dedicated from the CPU while the peripherals come from the chipset which has additional lanes. Even if you did add in more components the GPU would just step down to x8 speeds and would have a negligible impact on performance.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/#findComment-8206564
so i should still get the full performance from my gpu and still get the full speed from my m.2 ssd?
  • CPU
    Intel i7 6700k
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair AX860
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/#findComment-8206572
Yes you would :)
Prior Build Log/PC:
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/#findComment-8206576
Just now, Lurick said:
Yes you would :)
thanks
  • CPU
    Intel i7 6700k
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair AX860
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/#findComment-8206579
It only has 16 lanes not 20...
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/635801-cpu-pcie-lanes-help/#findComment-8206689
