980 TI stuck in Safe Mode
Solved by Vegetable,
Just now, Gatt said:Yeah, but it's not. Trust me. I've had this card for 6 months now. It's stuck in safe mode. I start any game, it doesn't even move.
That is odd. I would honestly uninstall ANY application on your PC that can modify/control your clock speeds. Essentially just DDU one more time, and before you install the graphics drivers again, uninstall afterburner/MSI gaming app/whatever else you have. When you're installing the Nvidia drivers (I'm assuming you're using geforce experience) click the "perform a clean install" button as well. Then go from there.
