just need some help, with new PC build with Windows 10 64 home it ran fine, but windows don't see the second CPU. With Windows 10 pro She saw the second cpu, then a work fine for a bit, but then gave me this error WHEA_UNCORRECTable_ERROR. I tried using safe mode (no Luck), Tried Resetting Window through recovery mode (no Luck), & at best their about before 5 minuets before she does it from the main windows. My question will I have reinstall windows manually, or can Microsoft fix it  from their end, since already payed for windows at bestbuy & got the Pro uprade from their microsoft store? SYS SPECS: 3 SSD's 2 HD's, 2 Xeon E5 2643, ASUS workstation MB, 96 GB RAM and a r9 390 from old PC. OR any ideal? Please & thanks
https://linustechtips.com/topic/635034-window-10-pro-issues/
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/635034-window-10-pro-issues/#findComment-8198572
