Was checking out some laptop at a retail store the other day and saw some of them are tablet styles, where you can detach it from their keyboards. This means all the hardware components are  installed on back of that LED screen, and its keyboard is basically a docking station. I wonder if any of them has ever thought up of actually putting 2 systems, where the keyboard dock will have a more powerful specs, compared to the ones that's installed behind the display? So when you run in laptop mode, it uses the components that's in the keyboard dock.
What I mean is this
2 in 1 laptop
Screen part - Core M CPU, 4-8GB of ram, iGPU 128-256GB SSD
Keyboard part - Core i3 - i7, 8-32GB of ram, dedicated GPU, 256-1TB of SSD.
Ram on the keyboard uses SO-DIMMs so they can be upgraded.
SSD runs on M.2 or in the 2.5" form factor
When you detach the screen from the keyboard, it runs on Core M, etc. Plug screen to keyboard and it runs on the Core i7.
https://linustechtips.com/topic/634728-dual-system-laptops/
6 minutes ago, Electronics Wizardy said:
No one has done this.
Its expensive, you run a different os(most people would hats this)
Less batter life
Heavy
You don't want to reboot.
The best way i could think to do this is using vms and live migration.
You are wrong. Microsoft did this with the Surface book. It works just fine, it doesn't affect battery as the bottom has it's own extra battery, it's not heavy at all and reboot is not needed.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195423
What I mean is this
2 in 1 laptop
Microsoft Surface Book is what you want I guess
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195425
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195426
Bottom only has a gpu, not anouther cpu and ram.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195429
Less batter life
Heavy
I just thought about the OS where it can only run from the SSD that's in the screen. Plugging to the keyboard dock means the SSD in the dock is just for storage.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195433
Still. It's the same idea as the OP described. ULV CPUs are all 15W so not really hot
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195434
Microsoft has sort of done this for their Surface Book I think it's called.  The keyboard part contains a lower end Nvidia dedicated GPU with I think 1GB of VRAM last I had seen along with additional battery cells to extend the battery life while docked with the keyboard.
It's an interesting idea but way overpriced for what you get because MS wants to be greedy and charge an insane premium for the ultra portable form factor.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195440
That's because there is no competition. If you want a 2-in-1 like the SB - there is no alternative.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195451
Okay so my idea was basically a surface book, but I want the dock with to come with a powerful CPU, more ram and a better GPU like a GTX 980. Don't know what Nvidia gpu have in that surface book. Probably a ION or something.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195490
The SB has a 930M with 1GB of GDDR5
What you are describing is basically impossible.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195502
Less batter life
Heavy
I would say this qualifies, but it was never released. It seemed that Google and/or MS were not happy with the idea and put a stop to it.
http://www.theverge.com/2014/1/6/5280850/asus-transformer-book-duet-hands-on-ces-201
Honestly, it is my dream laptop. Give me x86 and decent GPU in the base. When docked, Windows. When undocked, a decent tablet.
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195509
True.  They really have no incentive to lower the price.
But for what it is the SB is a good example of aside from the horrible price.  Even if you lose the full tablet experience by using the keyboard dock having the added battery life and any sort of dedicated GPU is very nice for what is technically still a tablet.
Edited by Bleedingyamato
Fixed phrasing of first sentence.
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195838
While it's not technically impossible, just what OP wants would be ludicrously expensive.
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
https://linustechtips.com/topic/634728-dual-system-laptops/#findComment-8195861
