5 minutes ago, Tasi3gaming said:
how can i Access my nas from a diffrent router
specs of my nas
intel pendium 4 3.0 gh
1.50 gb of ram
with a 20 gb hard drive
and 5 gb hard drive with nas installed on it.
What do you mean access it from a different router? Do you mean how do you access it from a different network? If so, then you can SSH into your network then into the NAS, or you can setup a VPN on your home network and then create a remote connection to your network and connect to it as if you were at home.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/634646-need-help/#findComment-8194541
