So I am going to be trying my hand at doing a custom water loop for my system. It has a i7 6700 CPU and a single GTX 1080. I have been looking for over a week now into water cooling and I am just unsure of one thing. How much do I need? I plan on using a 40mm 360mm rad. But I cant figure out my reservoir. Would a mid sized reservoir be enough or do I need one of the larger ones? Or should I move to a thicker rad?
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/
Don't bother with reservoir  that much. Big ones are mostly just to show it off :)
360mm rad ... well that's minimum. Simple rule: 120mm rad space for each component + additional 120mm.
But if you have more space, I would recommend you to get either 480, or 360 + 240.
It will work with 360mm rad, but temps won't be that great. Also you will need to run fans a bit louder.
About thicker rads ... it's good so you can use fans at lower speed, because more air can get trough it, because thicker they are, less fins they have.
So thicker rad = same temps for lower fan speed. In most cases at least :) 40mm seems just fine for me.
Just let us know what you alread picked, and we can tell you what else do you need.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194460
1. The more radiator, the better. I would use 240mm for each part to cool. Still you would be fine with a 360mm.
2. Reservoir size is not really important imo, it's just more comfortable to fill your loop with a bigger one.
3. Thickness is not that important when it comes to radiators. 40mm would be fine and more quiet than a thicker one because your fans can don't need to spin that fast to move the air through the radiator.
4. There is one more thing with radiators: The number of fpi (fins per inch). I think 10 fpi is the most common, but there are also 20 fpi radiators, which obviously have more cooling performance, but again need faster spinning fans to push the air through the radiator.
5. I personally would already watercool the GPU, if you can afford good waterblocks, since you get a lot better temps.
6. Good watercooling parts are really important. If you don't have the money for good waterblocks and so on, wait and save money until you can afford them.
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194467
Just now, Mobby Dick said:
I don't think they have neccessarily less fins, you can still choose different numbers of fpi.
Yap that's true.
But usually we go for more thick rads, because less fpi and we can run fans slower.
But yeah ... you can get thicker rad with even more fpi than some slim rads. But That would be a bit crazy.
Imagine 60mm rad with 24fpi ... you would need tornado to move air trough it xD
WD My Cloud 4TB
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194480
I just noticed something.... You said you have a 6700 and want to watercool it, but that's a locked CPU?!? Unless you made a typo, you won't really get much out of watercooling unless you really like the looks of wc and want to do it for fun.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194494
Yes this is what I have. I really don't have a drive to OC the CPU or the 1080. I am just thinking of taking the next step in building my PC and upgrading.
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194824
So you said 120mm for each component + 120mm for overhead. I only plan to do CPU and one 1080. So a 360 rad would fit that? Or does the 1080 just put out that much heat?
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194833
A 60x360 rad is probably enough if your not overclocking imo
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8194849
Sorry for late reply.
Yeah 360mm will work, but when you OC everything to the limit ...that might be a problem.
That's why we always recommend as much rad space as you can fit in your case.
120mm for each components + aditional 120mm is bare minimum.
WD My Cloud 4TB
https://linustechtips.com/topic/634637-cpu-water-loop-gpu-later/#findComment-8209253
