RM650X EPS and pci-e
Solved by STRMfrmXMN,
Just now, SpeederT12 said:Are you sure? I've heard that if I plug the eps connector into the 6+2 pin it would fry the cpu...
To be extra safe plug the 4+4 pin into the very top right-most port. I would think you would be fine as they both operate on the 12V rail, however. Just be safe if you're that concerned.
Featured Topics
Peregrine1 ·
Posted in Troubleshooting0 -
Tyraenel ·
Posted in Servers, NAS, and Home Lab3 -
XxWOODSIExX ·
Posted in Troubleshooting2 -
Pove ·
Posted in New Builds and Planning7 -
4
tommmie20000 ·
Posted in Audio5 -
INotPablo ·
Posted in Cases and Mods2
