Linux Distro for Web Development And Programming
Solved by riklaunim,
On 28.07.2016 at 4:36 PM, aneil1998 said:I'm currently trying to find a linux distro that is suited for web development and programming as the title says.
Short answer - any. Software is not tailored to given distribution. I use PyCharm and that's an IDE that is cross platform, not only Linux. If you need something more like good Docker support then it may differ a bit. But in general any distribution can be used for web development, programming. So it ends up on your system preferences, distro quality, ease of use, support and whatnot.
