Minimum requirements help
Solved by pwn_intended,
2 minutes ago, Matty2048 said:So if I turned the settings down to 720p and low settings it'll run fine ?
Hello and welcome to the forums!
It should definitely run at low-medium settings. Only one way of finding out how it will run on your specific system though...
kerriya ·
Posted in Cases and Mods4 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
