No. it will not affect rendering times at all. However it may improve the interaction speed in your program. Or if you need to load objects into your program to be rendered or modified, it could help with that. but typically, faster speeds will not help in a situation like yours as far as I'm aware.
https://linustechtips.com/topic/633310-pc-help/#findComment-8174637
as long as your hdd is faster than your cpu encodes/renders (which is by mostly any drive the case), you won't notice anything.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/633310-pc-help/#findComment-8174868
24 minutes ago, TechMaster said:
Will getting a faster hard drive/SSD improve my rendering times? Thanks
You will have to upgrade your cpu.
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
https://linustechtips.com/topic/633310-pc-help/#findComment-8174955
