20 minutes ago, thecanadianleaf said:
i recently bought some more fans for my spec 01 and they won't mount on the rear exhaust mount or top mounts any ideas how i could fix this?
Hi! Do you have photos of the issue?
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
3 minutes ago, thecanadianleaf said:
no, sorry the screws are to small for the mounting holes
What fans and screws are you using?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
10 minutes ago, thecanadianleaf said:
af120 quiet edition and the screws that came with them didn't fit the case
The screws screw into the fan and not the case.
6 minutes ago, thecanadianleaf said:
what? i mean i got the fans to install in the front but they wouldn't install anywhere else
That's weird. I've heard that the screws they come with are a bit more finicky than normal fan screws. If you have those lying around, you should try using them.
Again, you need to quote a post or tag a member or else they won't get a notification you replied to them.
14 minutes ago, thecanadianleaf said:
do you know where i could find "normal" fan screws?
Where are you shopping/located?
Any store that sells PC hardware also has mounting stuff.
Getting bit frustrated now, are we?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Nah, I'm pretty used to it but I find that bold red lettering helps make it clear for those who missed it the first two times around.
Thats odd. I have the exact same fans with the spec-03 and I didnt have any issue installing them. Did you try the screws that came with the led fan of the case?
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
