We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171823
1 minute ago, Energycore said:
i'm backing the S if you're looking for simplicity, and dont need 5.25" bays or more than 3 hard drives.
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171830
2 minutes ago, nick5530 said:
Yeah, but it is almost $100 at Newegg and no listed at Amazon, and those two are the retailers that I order from.
Then I'd say it's a wash between s340 and Enthoo Pro (the Enthoo is too big for my tastes, even the s340 feels bulky campared to what I have)
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171857
I think I will go with the S340 then because I don't want to buy an extra fan with the Enthoo Pro.
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171862
Or one of these.
http://pcpartpicker.com/product/qCR48d/nzxt-case-s210e001
http://pcpartpicker.com/product/chh9TW/enermax-case-eca3280abl
In particular the Enermax is built like a $80 case and it's got a rebate
@nick5530
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171870
NZXT S340 That case is beautiful af
I'm a person, you're a person...Together, we are people.
Bob Ross is the greatest painter ever! Happy trees!
Specs:
Processor: i7 4790k @4.7ghz
Game destroyer: Msi GTX 970 4GD5 OC (Soon to be a 1080 or Titan)
Mobo: MSI Z97I AC mini ITX motherboard
Fridge: NZXT Kraken X31 120mm liquid cooler
Lambo: Samsung 850 EVO 120gb SSD
Honda Civic: Random Toshiba 2TB 7200rpm HDD
PSU: EVGA Supernova 650 g2 (Currently out for RMA)
Case: NZXT S340 Midtower PC case
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171882
Minus points for bad stripe continuity :P
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171893
LOOL! I wasn't going for that type of style :D
Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171900
Damn doe. What you can do with a simplistic case.
I have concerns with the s340 because it doesn't ventilate its hard drive cages, unless you make the entire case flow back to front.
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171910
Tbh, I've never had any problems with it. The hdd will have enough space to breathe from the PSU vent and the little air flow coming from the fans up front.
Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171930
Look to the right of the ssd's there are vents and under that is where the hdd's go
Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171941
I guess that's not so bad. I'd personally mod a fan in there
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171948
If you want to. It should be fine though.
Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171965
I've been debating whether to mod my shit case into a great one or just get an S340, but since I've modded quite a bit I think I'm all-in now xD
Once I finish the mods I will post about them.
Computer Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171980
Cool, followed ;)
Specs:
https://linustechtips.com/topic/633090-best-70-case/#findComment-8171987
SuperBiiz and NCIX are fine to order from, for the record. My small PC company buys bulk from them.
https://linustechtips.com/topic/633090-best-70-case/#findComment-8173610
You used the same mentality as I used when choosing my case for my first PC build. What is the "best" case.
There is no best case, in fact, there are so many reputable manufacturers that sell reliable and high quality cases, that many cases, as long as the reviews are good, are just as good at each other.
There are essentially only a few things you should consider once you've found a case in your price point, (and compatibility like form factor):
1. What year was it released to the market? (Surprisingly important). I bought a fractal design R5, which is an older case, but STILL one of the most highly rated out there. However, I regret this decision because there are new cases out like the cooler master master case and the enthoo cases and whatever that look great and have more features, but are also highly rated. Often, newer cases are more applicable to a new PC build and are generally better.
2. Will everything fit inside (besides it being simply ATX), make sure that your GPU will fit, and your CPU cooler, and your reservoir (if you are doing this), do you need 100 drive cages for your 100 raid SSDs?
3. If you want a sexy case, get a sexy case, because once you make this beast build you will love to stare upon its chassis, and if you got a fractal design r5 case like me, (dont get me wrong, this is a great case and is very inconspicuous), I would have liked to have a sexier case.
https://linustechtips.com/topic/633090-best-70-case/#findComment-8173970
