I recently built a gaming computer in an ultra small form factor using a Mini-ITX Z170i MOBO.  I find the the integrated sound card/drivers by Realtek, while able to process 24bit @ 192K it still leaves a LOT to be desired in terms of consistency and quality.  I've been researching the best solutions for external sound solutions and find that there are a number of solutions out there, active monitors (I have a Focusrite Scarlett 2i2) external amplifiers, 5.1 systems, USB type sound cards (designed mostly for laptops), and a plethora of other options.
Tell me, what do you guys think is the absolute best external sound solution and the best budget friendly solutions. I want to know what you guys think?
-JWAL
PS: I am VERY new to forums and lurk more than I post so forgive me for improper etiquette.
If you guys want to see the video that inspired my ultra small but oh so powerful ITX gaming rig check it out here:
https://linustechtips.com/topic/633054-mini-itx-external-sound-solutions/
-JWAL
https://www.amazon.com/Focusrite-Scarlett-Studio-Interface-Recording/dp/B00AW91CPG?ie=UTF8&creativeASIN=B00AW91CPG&linkCode=w01&linkId=HTB7UCNBIWU3IGPW&ref_=as_sl_pc_ss_til&tag=techs096-20
tech source uses this one
for $200 comes with mic and headphones
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
16 minutes ago, crysilis said:
i'm not sure if you realised you did this or not...
oh SHIT LOL xD
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
15 hours ago, SSL said:
Remind me why you can't connect speakers and/or headphones to your Scarlet interface?
I'm tying to find an option for Speakers.  Headphones work fine but I would like to have a good speaker setup too.  I have a PA system I use for events but other than that its a super crappy creative 5.1 system (Realtek drivers) and the PA is way too much power.  So perhaps the better question would be in addition to a Focusrite Scarlett 2i2, what would be the best solution. Active monitors, amplification on bookshelf speakers....?
I haven't seen a budget yet.
